KevinA 695 Report post Posted February 13, 2018 12 hours ago, knightryder said: So mode 2 and 3 are essentially the same?? You can't accidentally activate FFS or LC so why bother having them in a separate map mode? Think you will find all the Ecutek tuners use much the same format, user desired functions can be requested and sorted. As they say "cant cater for everybody" Share this post Link to post Share on other sites
Kodename47 446 Report post Posted February 13, 2018 57 minutes ago, KevinA said: Think you will find all the Ecutek tuners use much the same format, user desired functions can be requested and sorted. As they say "cant cater for everybody" Just seems pointless, its that mental thing that 3 is worse than 4. You could have no mode 2 in that list and it wouldn't make any difference to the experience. Share this post Link to post Share on other sites
KevinA 695 Report post Posted February 13, 2018 Wish I had a pound for everything that's pointless in life probably be a rich man by now !! Share this post Link to post Share on other sites
Lauren 2259 Report post Posted February 13, 2018 6 hours ago, knightryder said: Just seems pointless, its that mental thing that 3 is worse than 4. You could have no mode 2 in that list and it wouldn't make any difference to the experience. Launch control, flat foot shifting and auto throttle blip are all gimmicks anyway. I opted not to have the throttle blip at all as I simply don't need it. I have flat foot shifting and launch control on two of the maps. Tried flat foot shifting once, didn't think it was kind to the car so never used it. Launch control I've no idea how to use so never bothered. I do though have Map 3 as a full power map but with reduced throttle sensitivity as Mark found it hard to control as it's pretty sensitive on the first two maps. Ironically he's not on my insurance anymore. Share this post Link to post Share on other sites
Paul 442 Report post Posted February 13, 2018 @Lauren Clutch in, Accelerator pressed hard down, LC will bounce of it's defined limiter, release clutch. Just in case you wanna try it. 1 Lauren reacted to this Share this post Link to post Share on other sites
Lauren 2259 Report post Posted February 13, 2018 5 minutes ago, Paul said: @Lauren Clutch in, Accelerator pressed hard down, LC will bounce of it's defined limiter, release clutch. Just in case you wanna try it. Yeah, I might try it. Is the limiter for it defined already? There's no way I can sit there with my foot down bouncing off the rev ilmiter. I do wonder how advisable this is on a clutch that's done over 110K miles! Share this post Link to post Share on other sites
Paul 442 Report post Posted February 13, 2018 2 minutes ago, Lauren said: Yeah, I might try it. Is the limiter for it defined already? There's no way I can sit there with my foot down bouncing off the rev ilmiter. I do wonder how advisable this is on a clutch that's done over 110K miles! Mine was set at 5k by default, if you flick the cruise control stick up/down while in LC mode it ups/reduces the LC limiter value on the fly. 1 Lauren reacted to this Share this post Link to post Share on other sites
KevinA 695 Report post Posted February 13, 2018 I have tried both and LC seems for me to less reliable than the old fashioned clutch and throttle matching. Launches are the easy bit for sprinting. Share this post Link to post Share on other sites
Kodename47 446 Report post Posted February 13, 2018 By default the LC is set to 4k rpm but TD may have changed it. You can adjust it, usually in 250 rpm steps, by knocking the cruise control up or down when at the limiter. I think 4k is still high, on my car it's set to 3k and even then the torque is too much. I find that FFS just doesn't feel natural so never got it it work, don't feel comfortable with my foot planted to the floor when changing gear Share this post Link to post Share on other sites
Lauren 2259 Report post Posted February 13, 2018 2 minutes ago, knightryder said: I find that FFS just doesn't feel natural so never got it it work, don't feel comfortable with my foot planted to the floor when changing gear That was my feeling too, so I opted not to use it. It seemed to drag the clutch and well I'm trying to see how many miles I can get out of the original clutch, it's almost become a challenge now. I normally launch the car manually at around 2.5K trying my best not to ride the aforementioned clutch. Share this post Link to post Share on other sites
LeviDane 14 Report post Posted February 25, 2018 Me and a friend found a private area today, just long enough to do a lil pull on. His car is completely stock and mine has tuning developments EL, overpipe and miltek exhaust with a tune. A good visual on the difference it makes. We did many pulls and even switched cars. The difference is noticeable. Next i want to get some 0-60 times. I need some new wheels though i am on stock ones which lose grip so easily. Tuned GT86 vs Stock GT86 3 1 alucardo, Mike@TD.co.uk, VAD17 and 1 other reacted to this Share this post Link to post Share on other sites
Mike@TD.co.uk 467 Report post Posted July 4, 2018 We've got the shelves stacked up with EL & UEL manifolds now - we also have free fitting on any other of our exhaust items when taken with a tuning package. Second Decats (Silenced & Un-Silenced) CAT Backs (Non-Res, Res & Super Res) Thanks! Mike Share this post Link to post Share on other sites
alucardo 55 Report post Posted September 1, 2018 TD resonated cat back, manifold and downpipe if any of you where wondering what it sounds like 2 Mike@TD.co.uk and Luke reacted to this Share this post Link to post Share on other sites
Luke 193 Report post Posted September 1, 2018 5 hours ago, alucardo said: TD resonated cat back, manifold and downpipe if any of you where wondering what it sounds like Is that uel or el? It sounds quite rx8 like. Share this post Link to post Share on other sites
alucardo 55 Report post Posted September 2, 2018 Equal Length. I was surprised it sounded quite good as I was not expecting it. Share this post Link to post Share on other sites
Luke 193 Report post Posted September 2, 2018 Did you get a sound db test before you went on track? Share this post Link to post Share on other sites
Lauren 2259 Report post Posted September 2, 2018 30 minutes ago, Luke said: Did you get a sound db test before you went on track? He wouldn't have done as they only do drive by there. Share this post Link to post Share on other sites
alucardo 55 Report post Posted September 2, 2018 As @Lauren said I was not db tested. I think I would be ok on just about all tracks about from Bedford these days. Share this post Link to post Share on other sites
Luke 193 Report post Posted September 2, 2018 Thats a shame. Still it's really good that you can get on track with a full exhaust system less the second cat. Share this post Link to post Share on other sites
Lauren 2259 Report post Posted September 2, 2018 2 hours ago, alucardo said: As @Lauren said I was not db tested. I think I would be ok on just about all tracks about from Bedford these days. You'll be fine everywhere but Bedford (and Thruxton). That's no great loss though. If you've driven Donington you won't be that interested in Bedford. I've had no problems with noise with all the circuits I've been to running the same setup, TD EL, TD resonated system and no cats. Share this post Link to post Share on other sites
Tom 5 Report post Posted October 6, 2018 Hi Guys So just come back from TD. They done ECUtec mapping for me ( had already k&n panel filter TD manifold, overpipe,superresonated cat back ) and I have to say car is much better now ( did tested on 190 miles drive back ( in the rain lol). Not only has got more power but is more economical too ( on the way there 41.4mpg on the way back 47.2 mpg and I was less economical on the way back!) So if someone is still thinking if is worth it ... do it ( if not for more power then for better mpg ;-) ) Highly recommend Tuning Developments, and very happy with they work. Now time to save money for turbo kit ;-) Share this post Link to post Share on other sites
Luke 193 Report post Posted October 6, 2018 Wow its improves the mpg!? Is that because you have more torque so down shifting isn't always required when at cruising speeds. Do tuning developments provide the gum as well? Share this post Link to post Share on other sites
Tom 5 Report post Posted October 6, 2018 34 minutes ago, Luke said: Wow its improves the mpg!? Is that because you have more torque so down shifting isn't always required when at cruising speeds. Do tuning developments provide the gum as well? Lol no gum is just to cover the reg. After remap you have quiet a bit more power and torque in 3000-4750 rpm range and that's what you use in normal driving so probably that's why mpg is improved Share this post Link to post Share on other sites
VAD17 479 Report post Posted October 6, 2018 Hi Guys So just come back from TD. They done ECUtec mapping for me ( had already k&n panel filter TD manifold, overpipe,superresonated cat back ) and I have to say car is much better now ( did tested on 190 miles drive back ( in the rain lol). Not only has got more power but is more economical too ( on the way there 41.4mpg on the way back 47.2 mpg and I was less economical on the way back!) So if someone is still thinking if is worth it ... do it ( if not for more power then for better mpg ;-) ) Highly recommend Tuning Developments, and very happy with they work. Now time to save money for turbo kit ;-) You will love TD turbo .Still remember driving from Warrington to London via M6 Toll road, lot of fun.Super Res also keeps it quiet, good for any track.Sent from my SM-G930F using Tapatalk 1 Tom reacted to this Share this post Link to post Share on other sites
BRZ-123 174 Report post Posted October 7, 2018 Great news Tom. Thanks for sharing.If I read your post correct, you had the hardware fitted by yourselves before going to TD and your ECU has relearnt what it could and adjusted aka your before run is with all hardware installed and your after is just with the tune to perfect the hardware.If yes, yours is a very unique example of these graphs and should be stored for future ref.Sent from my SM-G935F using Tapatalk Share this post Link to post Share on other sites
