Jason_E
The Tyre Thread
4 hours ago, Subota Boy said:
Interested to know, does a 225/45 not work as well as a 215/45 on the standard rim?  Any advice/opinion appreciated.
No, 225 is too wide for the meagre 7" rim. Will result in a taller sidewall due to the increased width proportional to the profile which will make it worse. Don't do it.
Wear wise, I go through three sets of rears to one set of fronts. So 7K for the rears and 21K or so for the fronts. I don't rotate my tyres.
3 hours ago, Rich said:
Had my Advans on for just over 10k miles now. Around 4mm left all round (marginally less at the rear than front). Very pleased with the wear rate, seems I'm easy on the tyres. ;)
I pretty much went through a set of fronts in ~14k :unsure:
It must be your driving styles. :P
I do appear to be light on everything apart from rear tyres for some reason.
Must be all those burnouts. :D
Just now, KevinA said:
40 up to 235 then 35 after that.
Im running 235/40 stretched on a 9J rim. 3% faster so the speedo will be spot on.
AD08R are wide for a 235 though.
Will go for 245/35 if I decide to go for CUP 2s
24 minutes ago, TTR said:
Is anybody running on 245/40/18? Really want Pilot Sport 4's, but they don't come in a 245/35/18 fitment :(
That's gonna throw your speedo off by some way. I'm having the same problem currently, as I want PS4's in that size. I'm either gonna go 235/40s or 245/35 AD08R's or something.
Throw it off? It under-reads anyway. So I usually go by GPS speed on my headunit and then just work from there on the tacho.
Problem for me is, I'm on 9.5" wide rims and don't really want the stretch that comes with the 235 and the 255's that are on there at the moment are just a tad too big haha.
Comparing to stock sizes, that tyre will under-read the speedo by almost 6%, that's quite significant. I don't know what sizes you have currently, but I'm assuming 255/35. Your current setup under-reads the speedo by almost 3%, and going to 245/40 will make it a further 3% worse, not fix it. Use this for reference http://www.willtheyfit.com/index.php?width=255&aspect=35&diameter=18&wheelwidth=9.5&offset=40&width2=245&aspect2=40&wheel_size=18&wheel_width=9-5&offset2=40
Going to a 245/35 will correct your speedo error by a little over 1%, which takes it closer to stock. Might be worth looking at other tyres in the correct size rather than the right tyre in the wrong size.
Big sidewalls, will flex a fair bit. As other's have said, get a different tyre in a better size. It seems like PS4's are the latest must have for some reason.
The speedo error I had stock was about 10%. Would read 77, with 70 on GPS. So, going to 245/40 would make it 3% worse than what I currently have, but still not as bad as stock. I'm not really sure whether the issue you're getting is actually that fucking important for when I'm pushing on :lol:
My concern is the amount of sidewall on a 245/40/18, is the sidewall/diameter/circumference increase going to be an issue and has anybody with experience of said tyre fitment got any comments to make vs what i'm currently on.
Thank you for answering the concern that I had Lauren, much appreciated :lol:
It'll be shite. I've driven a GT86 with this size tyre on track. Not good.
As previously said, thank you for actually providing the information I was after :lol:
Here's a tip. Rather than being a dick when someone gives you an answer you weren't interested in, maybe be a little more concise when you ask the fucking question.
Your question didn't mention you were "concerned about size of sidewall", and my answer didn't mention that as I have no experience of that issue, I just gave you information perfectly relevant to your question that I could find to help you out. Remind me not to bother wasting my time on you again.
How was I being a dick? There was no malice in my comments :lol:
Pretty sure the below would give off the indication that what you mentioned wasn't relevant to my question. But anyway, no malice in my comments.
Below is another indication that my question was about sidewall, highlighted in bold.
Don't be so quick to take offence on the internet bud, Lauren got my concern first try :P
Your question was about tyre sizes, not sidewalls. If you wanted to ask a question about sidewalls, you'd have asked "Will the sidewall be too large on a 245/40?", or "Will the car drive poorly on 245/40?". You didn't. You asked a general question about tyres and I gave you a general concern.
Lauren answered your question in the way you "wanted" because her first consideration when answering questions is usually "How will this issue effect how the car drives?". I don't have that knowledge as I've not driven any car other than my own in anger, and I'm not gonna guess just to be helpful, but I wanted to be helpful. I know that one reason people stick to certain tyre sizes in general, is to keep speedo readings fairly accurate. Ok, that's not a concern to you, but my name is Ross, not mystic Meg, so there's no way for me to know that.
Also, I'll never take offence to anything you say to or about me, don't flatter yourself ;)
It's all down to personal preference and your driving style, I run wide tyres on wide rims without any problems. Not quicker or slower but feels how I like it, try different combinations if you have the chance and settle for what feels right.
I admit, I haven't tried the current F1's though in a way I have, driving Keith's turbo GT on track with 245's. F1s tend to be soft on the sidewall and don't tend to take track abuse well. Great for the road though, probably.
