Gringosteve
ECU Setting Customisation
Hi All,
Have any of you tried this iOS/Android app@
http://www.caristaapp.com/
It appears to allow you to update config settings using OBD2 adapter.  I have the necessary hardware for this, but it costs money to enable the feature to save settings so have not tried it yet.  It supports the following on my car, although the website suggests it should support some more options around climate control settings.
Doors / Windows / Remote:
    Blink turn signals when locking/unlocking with remote
          YES / NO
    Beep when locking/unlocking with remote
          YES / NO
    Volume of beep when locking/unocking with remote
          OFF / 1 / 2 / 3 / 4 / 5 / 6 / MAX
    Warn when door can't be locked with remote because it's open
          YES / NO
    Panic function on remote
          ENABLED / DISABLED
    Open trunk lid with remote
          SINGLE CLICK / DOUBLE CLICK / LONG PRESS / VERY LONG PRESS / DISABLED
    Re-lock doors automatically if you unlock, but don't open a door
          YES / NO
    Re-lock doors automatically if you unlock, but don't open a door within…
          30 SECONDS / 60 SECONDS / 120 SECONDS
    Unlock doors via remote
          DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / ALL DOORS ON 1ST PRESS
Instruments / Display / Dings:
    Key-in-ignition ding sound
          SLOW / MEDIUM / FAST
    Ding when headlights are left on
          YES / NO
    Seat belt warning ding (driver)
          ENABLED / DISABLED
    Seat belt warning ding (front passenger)
          ENABLED / DISABLED
Lights:
    Daytime running lights
          ON / OFF
    Coming-home lights duration
          OFF / 30 SECONDS / 60 SECONDS / 90 SECONDS
    Auto headlights activation threshold
          DARKEST / DARKER / NORMAL / LIGHTER / LIGHTEST
    Dim interior lights after…
          7 SECONDS / 15 SECONDS / 30 SECONDS
    Turn on interior lights when you shut off engine
          YES / NO
    Turn on interior lights when you unlock doors
          YES / NO
    Interior light control
          ENABLED / DISABLED
Just incase you wanted to know the default settings on my car ( default surrounded by *'s:
*YES* / NO
OFF / 1 / 2 / 3 / 4 / *5* / 6 / MAX
*YES* / NO
SINGLE CLICK / DOUBLE CLICK / *LONG PRESS* / VERY LONG PRESS / DISABLED
*30 SECONDS* / 60 SECONDS / 120 SECONDS
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Unlock doors via smart key (door handle button)
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
After locking with smart key, allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
Smart key location to start car
FRONT SEATS / *ANYWHERE IN VEHICLE*
Unlock trunk when smart key in range
*YES* / NO
Engine start indicator
*ON* / OFF
*SLOW* / MEDIUM / FAST
*YES* / NO
*ENABLED* / DISABLED
Remote low battery warning
*ON* / OFF
Lights
*30 SECONDS* / 60 SECONDS / 90 SECONDS / 120 SECONDS
DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
7 SECONDS / *15 SECONDS* / 30 SECONDS
*YES* / NO
*YES* / NO
Turn on interior lights when smart key in range
*YES* / NO
Yes, so far changed auto light sensitivity so they go off when it is dark rather than when the sun is a bit low or shadey :)
I tried the engine start indicator but couldn't see any difference.
The Lock bleep option doesn't seem to do anything as the UK cars don't bleep. I have the alarm bleep when I lock the doors instead (an alarm customisation option)
More tests tomorrow!
Sadly not, I don't think the necessary cabling exists and the option isn't there :( I have asked to join the beta program and have uploaded my debug data to hopefully unlock more options.
The latest android beta version has additional tools but you need a Bluetooth OBD to work with android. Mine is is wifi
how do you get the beta? I have a bluetooth OBD so could check it out
Beta is now installed.  It gives control of the heater settings.  I have used it so far to:
1) not turn on AC when i turn on front demisted
2) Remove a -1c calibration on the temperature dial.  I often though it was under reading, so will give that a try.
Additional tools such as service indicator resets (not needed on our cars) etc will be coming shortly also.
